NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 01, 2015 03:15PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 01, 2015 07:54PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 12:47AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 01:52AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 02:24AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 03:03AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 03:34AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 03:52AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 03:54AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:02AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:17AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:23AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:29AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:33AM |
OO DURKE OO
Hello Doug
The bed is leveled and a piece of paper goes between them without issue. The problem is when the printer starts the printer raises on the z axis and is no longer where it needs to be to lay plastic. So instead of being just above 0 its at something like 0.30 and then starts printing. This happens from an SD card read and also from CURA. though Cura is much better.
As far as what controls the switch what do you mean?
I have a Prusa reprap i3 and I mounted the z axis switch where it should be. I did not see any instruction for adjustment. it looks like just a piece of metal over a plastic button and clicks when its hit.
from the mount location it just wires into the mother board.
The print bed is where it should be and wont go higher in the molded casing.
So basically just my z axis keeps going to high to reach the print bed once the printer actually starts running and im not sure how to change that.
the bed and extruder are where they should be but the extruder is just to high to lay plastic on the bed ON ALL prints.
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:36AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:43AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:45AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:47AM |
OO DURKE OO
How do I find those things? While I am technically apt, I am new to this type of hardware/software. So I have no clue where to find things like that. I am using the software that the motherboard and LCD came with.
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 04:49AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:01AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:03AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:06AM |
OO DURKE OO
no software files except for Cura and the Driver. And those took some looking to find on the disc. The steps also do not list anything for firmware installation either. This printer was supposed to be basically assemble and ready to go but it is turning out to be a hassle and then some to get this dang axis working right.
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:08AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:09AM |
dougal1957
OO DURKE OO
I have seen other post's from users of this machine (Think you will find them on page 3 or 4 of this section if you scroll down it may be worth a PM to those guys.
Also if you watch the LCD screen when it boots up it should tell you the Firmware version guess it will be Marlin vx.x.x or whatever having that info may help. else you could try and use Repetier Firmware (I can give you pointers to that if needed) and it has a very nice online configuration tool.
also try downloading Repetier Host as that can interrogate the contents of the EEPROM so we can see what has been set.
Doug
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:39AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:43AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:48AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:49AM |
M502 resets back to factory settingsQuote
OO DURKE OO
This is an image of my LCD screen after the bed heats it sends everything to this setting which in turn causes my Z axis to be higher than the beds actual level.
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 02, 2015 05:50AM |
