Hi everybody,
while trying Slic3r, Cura and Pronterface, I found out about OctoPrint. Having had a Raspberry Pi (=: RPi), I immediately tried it. A single print went good but now, I am having the following troubles.
Selecting an arbitrary gcode file (sliced from Slic3r or Cura, doesn't matter from where), Octoprint makes the printer heat up and move the nozzle to the bed's center. Right at the point a regular print would start, I am getting an error!
The error messages follow here:
This can be found in the terminal tab:
Recv: Error:Line Number is not Last Line Number+1, Last Line: 14
Recv: Resend: 15
Send: N15 M117 Printing...*47
Recv: ok
where there are many of these lines with different "Last Lines". Also, this can be found in the terminal tab:
Recv: Error:Line Number is not Last Line Number+1, Last Line: 22
Recv: Resend: 23
Send: N23 G1 X110.435 Y91.970 E0.30136*96
Recv: ok
Recv: ok
Send: M105
Recv: Error:Line Number is not Last Line Number+1, Last Line: 23
Recv: Resend: 24
Changing monitoring state from 'Printing' to 'Error: Printer requested li...'
Recv: ok
Recv: Resend: 24
Recv: ok
Recv: Resend: 24
Recv: ok
Recv: Resend: 24
Recv: ok
Recv: Resend: 24
Recv: ok
Recv: Resend: 24
Recv: ok
Recv: Resend: 24
Recv: ok
Recv: ok T:204.3 /205.0 B:79.9 /80.0 @:104 B@:0
Changing monitoring state from 'Error: Printer requested li...' to 'Closed'
Changing monitoring state from 'Offline' to 'Opening serial port'
Connection closed, closing down monitor
Taking a deeper look into the actual octoprint logging files, I can find:
octoprint.util.comm - WARNING - Printer requested line 24 but no suficient
history is available, can't resend
Do you guys might now what the problem might be? A short summary to make everything clear: Initializing a print and right at the moment when the printer is at the x-y-center and nozzle down on surface, the process stops and Octoprint disconnects automatically.
I am thanking you a 1000 times in advance! :-)
Bests and have a good evening,
m
