24"x24" Prusa I3 Bed Power February 02, 2015 10:55PM |
Re: 24"x24" Prusa I3 Bed Power February 02, 2015 10:59PM |
Re: 24"x24" Prusa I3 Bed Power February 03, 2015 04:17AM |
Re: 24"x24" Prusa I3 Bed Power February 03, 2015 11:08AM |
+---/\/\---+ | | +---/\/\---+ | | | +---/\/\---+ | | | | +---/\/\---+ | | | |If each of these is a standard 100k thermistor, the result with these 4 will look like a single 100k thermistor to the firmware, which will result in them reporting the average temperature over all 4 locations.
Re: 24"x24" Prusa I3 Bed Power February 03, 2015 04:51PM |
Zavashier
Multiply external PSU and use relays. 13A/heatbed under 12v or 9A/heatbed under 24v. To me, the prusa i3 architecture is not scalable that much. You can increase a bit Y and Z but I would keep X dimensions as close possible as the original. Scaling a machine is not as simple as increasing dimensions. You should increase exponentialy structure profiles, guides and transmission. Price will increase exponentialy too. At last if you want to reach the same print quality as its parent.
Re: 24"x24" Prusa I3 Bed Power February 03, 2015 10:54PM |
SupraGuy
If you do this, you should probably use a sheet of aluminum or something with good thermal conductivity as a bed. The reason being that the gaps between the actual heated spots on the heatbeds is large enough to cause discrepancies in how the bed reacts.
For the thermistors, I would use 4, which can be connected using a series/parallel configuration which will average out the results into something that the firmware can understand:
Re: 24"x24" Prusa I3 Bed Power February 04, 2015 06:27PM |
Re: 24"x24" Prusa I3 Bed Power February 06, 2015 05:51AM |
Re: 24"x24" Prusa I3 Bed Power February 06, 2015 09:20AM |
Re: 24"x24" Prusa I3 Bed Power March 13, 2015 08:23PM |
Re: 24"x24" Prusa I3 Bed Power March 14, 2015 03:00PM |
Re: 24"x24" Prusa I3 Bed Power March 14, 2015 07:21PM |
Re: 24"x24" Prusa I3 Bed Power March 15, 2015 02:02PM |
