Home made printers may have very different results. Depending of too many factors : build quality, components, settings... One nozzle can be dirty, on belt may not be as tight as the other. A cartridge may raise in temperature more quickly, two thermistors can measure different temperatures. My advice is to calibrate each machine to get the best possible print quality. Just don't expect to have exactly the same results from two different printers, especialy if they use different nozzle size. Just because they won't print parts in the same amount of time.
Think about the nozzle like a pencil. Do different thickness pencils draw the same ?
Edited 2 time(s). Last edit at 02/06/2015 05:34AM by Zavashier.
Collective intelligence emerges when a group of people work together effectively.
Prusa i3 Folger (A lot of the parts are wrong, boring !)
