Long delay before print February 08, 2015 10:59AM |
Re: Long delay before print February 08, 2015 02:09PM |
Re: Long delay before print February 09, 2015 06:34AM |
IMBoring25
The hot end typically has low thermal inertia and doesn't take long to get to temperature. You're probably waiting for your heated bed to come to temperature which, despite lower operating temperatures, takes much longer due to high thermal inertia.
You can:
1) Make sure the heated bed power is adjusted properly.
2) Experiment with lower heated bed temperatures and see if you still get satisfactory results. Every degree you try to raise bed temperature takes longer to achieve than the degree before it.
3) Increase the room temperature and/or put the machine in an enclosure.
4) Put thermally reflective material above and/or below the bed, being careful not to short it.
Re: Long delay before print February 09, 2015 07:01AM |
Re: Long delay before print February 10, 2015 05:38AM |
Re: Long delay before print February 10, 2015 08:55AM |
waitaki
If you are using Slicr3, go to the "Filament settings" tab, select "Filament" and set all (4) temperatures to 0 (zero). Create the g-code for your chosen file.
If your have switched your hot-end and bed on to prepare for printing (ensuring they are up to temp) then as soon as you hit print, it will start immediately.
It is always a good idea to switch the bed on first because of the heating time, then, when its within 5 to 10 degrees of target, switch on the hot-end.
Re: Long delay before print February 11, 2015 01:21AM |
Re: Long delay before print February 11, 2015 08:08AM |
Re: Long delay before print February 12, 2015 04:20PM |
