Thoughts on belt and pulley wear
February 08, 2015 11:55AM
Using our printers every day, what might be a standard time frame for replacing belts and pulleys? Mine has about 4 months on it and is still doing well. Thoughts?
Re: Thoughts on belt and pulley wear
February 08, 2015 01:07PM
I think you sooner build a new machine than see you belts wear out.
February 08, 2015 01:50PM
I find good quality belts, pulleys, rods and bearings last about two years of near continuous use. After that they start to need replacing.
February 08, 2015 02:13PM
If you are buying high quality belts there will be full lifespan calculations in the technical data based on temperature, RPM and power transfer.
Most timing belts will last 6 years or more in a car.
February 08, 2015 05:31PM
On a reprap they can work as long as the rubber don't crack. The load on a repraps is so light ! The stepper motors and the bearings will fail before the belts !
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
February 08, 2015 06:15PM
I find the teeth wear down and start giving backlash. I think aluminium pulley teeth wear as well. 3D printers do a hell of a lot of mileage.
February 10, 2015 12:50AM
Well, that pretty much confirms that oiling the idler bearing was a bad idea. Live and learn. Like my father in-law says, why would you make the same mistake twice when there are so many new ones to make. Thanks guys.
P.s. Every time I say guys I wonder if I'm dissing any gals residing here. Are there ladies amongst us?
February 10, 2015 04:50PM
elwood127
It would be safe to assume there are. Could always say 'thanks all', or 'thanks folk' or something more generic like 'thanks much' if you want.
