Why using two motors? February 11, 2015 09:56AM |
Re: Why using two motors? February 11, 2015 12:01PM |
Re: Why using two motors? February 11, 2015 12:46PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Why using two motors? February 11, 2015 12:55PM |
Re: Why using two motors? February 11, 2015 01:46PM |
Re: Why using two motors? February 11, 2015 03:18PM |
Re: Why using two motors? February 11, 2015 03:56PM |
Re: Why using two motors? February 11, 2015 10:59PM |
Re: Why using two motors? February 12, 2015 05:16AM |
The belt is only for synchronisation. That's why you used so large pulleys without any issue (you're loosing torque throught). You surely already know, but for newbies it's important to make the difference. Don't forget the gantry leveling by turning a single screw is not meant to be done often, even if you use to change a glass plate at each print. Anyway, that procedure works with the bed leveling, which does the fine tuning. I've got my I3 set some hundreds of hours ago, and it stays pretty square. I just do some minor tuning by the bed (mostly control issues), each time I remove the glass plate for cleaning. I never had to turn any lead screw since the gantry is level.|
Re: Why using two motors? February 12, 2015 08:44AM |
Re: Why using two motors? February 12, 2015 12:54PM |
The bed must be square with the other axis of course. Bed leveling is just to fine tune while something changes, like changing/moving a glass plate or a nozzle. I'm new with 3D printing, that's true. I'm graduate in mechanical studies and I work as engineer in a company that develop and sales production machines for aviation industry, for 3 years now. I buided my first metalwork CNC mill when I was studdent in 2009. I'm not into electronics, but I've got some mechanical skills. Believe me or not, I install any machines with a very accurate precision. It's level and square within 0.05mm, as far the machine alows it. It was not that easy with my Prusa I3 as you can easily imagine. Through, by fixing the machine to a dead flat torsion box, I managed to square it up with a good precision. I've got no kids at home and I'm the single user of my tools, hopefully.
IMHO you square your machine when you install it with precision measuring tools. Machining or printing may confirm you've done that job properly, but to me the measurements you get are more precise than anything you can print. Compared to precision milling/turning FDM 3D printing is pretty rough. I will read your method anyway. Did you learned it from someone or did you experienced it by yourself ?|
Re: Why using two motors? February 12, 2015 03:30PM |
Re: Why using two motors? February 12, 2015 05:32PM |
Re: Why using two motors? February 12, 2015 11:02PM |
Re: Why using two motors? February 13, 2015 06:21AM |
Re: Why using two motors? March 29, 2015 11:39PM |
Re: Why using two motors? March 30, 2015 03:54AM |
RRuser
What are some examples of single-Z-motor printers for sale?
Re: Why using two motors? March 30, 2015 04:18AM |
Re: Why using two motors? March 30, 2015 09:44AM |
Re: Why using two motors? March 30, 2015 12:53PM |
Re: Why using two motors? March 31, 2015 06:04AM |
Re: Why using two motors? March 31, 2015 01:25PM |
Re: Why using two motors? March 31, 2015 05:52PM |
Re: Why using two motors? December 10, 2015 05:17AM |
Re: Why using two motors? December 10, 2015 06:03AM |
Re: Why using two motors? December 10, 2015 06:42AM |
Alan P
Hi All
I am having synchronisation problems while commissioning my first ever printer ( Prusia i3 ). It,s a self build from scratch, not a kit.
I am running two Numa17 motors on the z axis as usual for this design but they are getting way out. I suspect stiction.
I was thinking of adding a bearing and pulley assembly to the top of the lead screws so that both motors are driving (helping) each other via the belt.
So thats two motors and a belt .
Any comments on why or why not to do that ?
Thanks
Alan P
Re: Why using two motors? December 10, 2015 05:25PM |
Re: Why using two motors? December 10, 2015 05:30PM |
Re: Why using two motors? December 20, 2015 07:29PM |
Re: Why using two motors? March 17, 2016 04:58PM |
