PLA in heated chamber February 13, 2015 06:49AM |
Re: PLA in heated chamber February 13, 2015 08:34AM |
Re: PLA in heated chamber February 13, 2015 01:06PM |
Re: PLA in heated chamber February 13, 2015 07:46PM |
Re: PLA in heated chamber February 14, 2015 02:09PM |
Re: PLA in heated chamber February 14, 2015 04:28PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: PLA in heated chamber February 15, 2015 07:39AM |
nophead
the motors and extruder run at chamber temp plus about 20C
Motors Wantai 42BYGHW609
Stepper current up to 1.6A
#define DEFAULT_MAX_FEEDRATE {75, 75, 2.7, 20}
#define DEFAULT_MAX_ACCELERATION {750,750,60,2000}
#define DEFAULT_ACCELERATION 1000
print speed in Slic3r is 60mm/s infill, 30mm/s perimeters
My new printer has a different motor (slightly higher torque) so it will be interesting to see if I start to see hot motors when I complete that printer.Quote
They softened a bit at 45C and the nuts would never stay tight due to the washers sinking in.
Re: PLA in heated chamber February 15, 2015 09:35AM |
and use it as a temporary build chamber to print replacement ABS parts for use in your final printer.....
Re: PLA in heated chamber February 15, 2015 10:03AM |
Re: PLA in heated chamber February 15, 2015 10:09AM |
dc42
I'm not at all sure there is any point in a heated chamber for printing PLA unless your printer is in a particularly cold room. But it does help to shield the printer from draughts.
Re: PLA in heated chamber February 15, 2015 10:34AM |
I hear this all the time (that other peoples motors run hot), mine never even get warm to the touch.
Re: PLA in heated chamber February 16, 2015 07:58AM |
