First build - e3d v6 hotend with wade extruder February 27, 2015 08:31PM |
Re: First build - e3d v6 hotend with wade extruder February 27, 2015 09:58PM |
Re: First build - e3d v6 hotend with wade extruder February 27, 2015 10:08PM |
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 05:27AM |
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 09:14AM |
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 01:36PM |
So I looked at your parts, and I not able to confirm you can mount a E3D v6 even temporary. I mean It looks like you could, but I cannot be sure at 100%. Maybe you could ask the seller ?|
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 01:47PM |
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 02:51PM |
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 03:54PM |
riko47
In the part kit it says ABS parts? Yes it looks so. I've also read alittle about hos to attach the e3d with a Wade extruder and came to the same conclusion, you can never be to sure.
Should I run the e3d with the stock fan or buy another?
Any ideas about best nema motors? I've already said which nema motor model I'm choosing, but is this model the best to run a printer with? And should I really add 120g to the extruder for a stronger motor?
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 04:02PM |
Re: First build - e3d v6 hotend with wade extruder February 28, 2015 05:04PM |
Re: First build - e3d v6 hotend with wade extruder March 01, 2015 03:07AM |
Re: First build - e3d v6 hotend with wade extruder March 01, 2015 06:20AM |
Re: First build - e3d v6 hotend with wade extruder March 01, 2015 06:28AM |
Re: First build - e3d v6 hotend with wade extruder March 01, 2015 07:49AM |
Re: First build - e3d v6 hotend with wade extruder March 01, 2015 08:08AM |
Zavashier
For lazy people : the lenght of the motor is linked with available torque, your required torque depends of the efforts the motor will hold. Then look at the inductance, the lower, the better.
The choice of the motor is the result of a calculation for a specific situation. I won't explain the calculation procedure here. A lot of manufacturers give stepper motors selection guides. (It's easy if you try). So all depends of the machine itself and of what is expected. My advice, don't ask for someone to do your shopping, ask for knowledge (or where to get it). Get some skills.
Re: First build - e3d v6 hotend with wade extruder March 01, 2015 09:04AM |
Re: First build - e3d v6 hotend with wade extruder March 01, 2015 12:00PM |
