Extrustion test using LCD?
March 01, 2015 03:54AM
I have just built an i3 rework which doesnt use cogs for the extrusion motor, it's got a small silver aluminium cog that turns against a spring loaded arm which pinches filament. For the moment i haven't even been able to do an extrusion test. There is an LCD Ramps, and i can't find an extrusion test on it.
I have threaded the filament some kind of hole and hoped that it ends up on the aluminium extrusion cog, and searched for "extrusion test" everywhere, except it seems the Ramps LCD can't test extrusion? It has every possible tuning setting for the other motors except for the extrusion.
do i have to connect the printer to a PC and attempt calibrations from there?
Re: Extrustion test using LCD?
March 01, 2015 07:19AM
Normally ramps wont run the extruder if the thermistor for the hot end isnt at full temperature.
So you will need to disable minimum temperature or set it below ambient temperatue in the firmware.
What your looking for is called something else. Its often referred to as jogging or moving the axis.
The extruder is treated as just another axis in the firmware.
Not sure on your particular lcd but it should use simalar names in the navigation.
To find the extrude function in my full graphics lcd controller.
Look under prepare - move axis - select increment - extrude.
Extrude isnt under all of the increment values.
Its easier to use the pc to move the axis for calibration as you can select the distance then tell it to move.
But the smart controller will start moving as soon as you adjust the value.
The software like repetier gives you better control for calibration.
Gordon
Edited 1 time(s). Last edit at 03/01/2015 07:21AM by gordonendersby.
March 01, 2015 11:57AM
Thanks Gordon!
yes i find the extrude motor under the x y z axis control selection. managed to have my first time of 3d printing. very fun! just some various tweaks and it will be nice,
