[Steppers] End sockets March 04, 2015 08:34AM |
Re: [Steppers] End sockets March 04, 2015 10:03AM |
ishe7ata
Hey there,
So two quick questions:
My steppers came naked at the end with no sockets whatsoever. So I wanted to install those. Instead I was recommended to use these www.dx.com/p/1-pin-dupont-wire-connector-cables-40-pcs-20cm-151537#.VPcFNvmUe2U Which I already have now.
Can I strip those off and solder one to each stepper wire and then insert them in RAMPS? Essentially will they be able to take on the 1.8A rated current of the steppers?
Second is about the thermositers, any other alternative to using the NTC 100K? What about using a thermocouple (J Type) is it compatible with RAMPS??
That's all
Thanks
Re: [Steppers] End sockets March 06, 2015 07:23AM |
tjb1
ishe7ata
Hey there,
That's all
Thanks
Yes you can use those wires. RAMPS is not compatible with thermocouples without another board and in my experience it was more trouble than it was worth. I had constant issues with temperature readings jumping 10-20c every few seconds with an Ultimaker thermocouple board and I tried everything including an isolated supply for it. You would probably be better off with an axial thermistor, they are pretty durable and usually good to around 280c.
Re: [Steppers] End sockets March 06, 2015 08:14AM |
