Filament not extruding in bowden drive March 05, 2015 09:23PM |
Re: Filament not extruding in bowden drive March 06, 2015 11:30AM |
Re: Filament not extruding in bowden drive March 06, 2015 01:24PM |
Thanks! I will try to add support and also tighten bearing so it pushes on filament harder. I know it worked for others with same hotened...Quote
ggherbaz
From what I can see from the picture the length is fine, but you need to support the tube because those steep curves might cause problems, also a direct drive might be weak for your metal hotend.
Re: Filament not extruding in bowden drive March 06, 2015 04:39PM |
Re: Filament not extruding in bowden drive March 06, 2015 04:47PM |
Re: Filament not extruding in bowden drive March 06, 2015 05:14PM |
Re: Filament not extruding in bowden drive March 06, 2015 05:28PM |
Re: Filament not extruding in bowden drive March 06, 2015 05:29PM |
Re: Filament not extruding in bowden drive March 07, 2015 10:37PM |
