extruder gears are pretty useless March 05, 2015 10:01PM |
Re: extruder gears are pretty useless March 06, 2015 06:00AM |
Re: extruder gears are pretty useless March 06, 2015 11:10AM |
Re: extruder gears are pretty useless March 06, 2015 12:17PM |
Re: extruder gears are pretty useless March 06, 2015 12:36PM |
Re: extruder gears are pretty useless March 06, 2015 02:26PM |
Re: extruder gears are pretty useless March 06, 2015 02:27PM |
Re: extruder gears are pretty useless March 06, 2015 03:02PM |
Admin Registered: 17 years ago Posts: 7,881 |
Re: extruder gears are pretty useless March 06, 2015 03:08PM |
Re: extruder gears are pretty useless March 06, 2015 03:19PM |
Re: extruder gears are pretty useless March 06, 2015 03:22PM |
Re: extruder gears are pretty useless March 06, 2015 04:30PM |
Re: extruder gears are pretty useless March 06, 2015 04:40PM |
Re: extruder gears are pretty useless March 06, 2015 09:45PM |
Re: extruder gears are pretty useless March 06, 2015 09:59PM |
Re: extruder gears are pretty useless March 07, 2015 12:04AM |
Like most have said here, you might be feeding too much filament through it. I cannot tell you exactly what the steps/mm should be. You have to properly calibrate it. What I do to calibrate is remove the bowden tube, and extrude 100mm. I measure that with a caliper and do the calculations on what the steps/mm should be. This page [www.instructables.com] may help you get to the right direction.Quote
b3nnb
So I've been playing with that for hours and slowing things down has improved the extrusion a little bit. At this point it gets a couple layers into the raft and then jams. And I think I know what's going on. Every time it jams, I pull the tension bearing from the gear cover and the filament is always folded over itself on the side. The tension bolt is off to the side. So I think there is an angle of pressure if that makes sense. When I use my hand to add a little pressure to the side the bolt is not on, it seems to be reliabl .
Re: extruder gears are pretty useless March 07, 2015 12:55AM |
