uneven infill on 1st layer
Posted by Darathy
March 08, 2015 04:35AM
Hello ,i am wondering if anyone can answer why my ormerod 2 is doing good 1st layer on one side and bad on the other side (verry thin layer marked on picture ,sorry bad quality ,it didnt wana focus when it was moving) ,i do have bed compensation enabled and i did level the bed manualy as best as i could.
open | download - IMAG0184.jpg (401.9 KB)
Re: uneven infill on 1st layer
March 08, 2015 07:38AM
Try to purge the hotend with fresh filament before starting to print. Verify your bed is dead flat.
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
March 08, 2015 02:41PM
Does not look like uneven bed to me. My guessing is you are just a little too near bed when printing 1st layer.
You can adjust that in your start code just for testing
This code will rise 0.1 mm
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 Z14.9
G92 E0 ;zero the extruded length
Ha det gött
Bosse
Prusa i3 Reworked, Delivered March 28 2014, RAMPS 1.4
Göteborg, Sweden
March 15, 2015 01:29PM
Thank you for the replays ,it seems i had to recalibrate the Z home to get it fixed ,i'm am fairly new to 3D printing only gotten my Ormerod 2 a month ago and still learning. Thank you Sidhabo for giving me the idea. Sorry for the late answer didnt have much time to tinker and try.
March 15, 2015 04:08PM
Thanks for feedback Darathy. Always good for everyone to know about a working solution smiling smiley
Ha det gött
Bosse
Göteborg, Sweden
March 16, 2015 03:20AM
i was having the same issue. You may think the bed is completely flat and level with smaller prints, but i recently started doing large prints, max length, but narrow, and i was getting pissed that i would come back after 2hrs and it only printed the first layer, yet it finished and sat at park position. Small prints worked fine, but larger were failing. I realized it was my bed. Because in some areas it was too close, so it was clicking. Enough clicking and the heat travels up and jams the extruder. So i adjusted the print bed DURING a large print, until each section stopped clicking. I went into Cura settings and set FIRST LAYER HEIGHT to .5mm higher and now it's flawless on large prints.
All part of the learning process. Thankfully these pieces that fail only cost about $.07 lol.
March 20, 2015 01:38AM
I get this also but it is always on one side or the other of a hole. It's always in an area that it comes back to that it skipped ealier in the print. It's as if the head rises to get to the area and then drops to a different height. Could it just be slop? We're only talking a hair difference in smoothness.
