Prusa I3 wont print on bed
Posted by ebmoney08
March 12, 2015 08:14PM
Hi guys. I'm new to this whole world so forgive me. I have a folger tech Prusa i3 that i finished building tuesday night. When i slice something and try to print it always goes to the front left corner of the bed and just stats extruding a bunch of filament. when i looked at the g code i noticed that all the axis coordinates seem to be 200 higher then what they should be. example:; generated by Slic3r 1.1.7 on 2015-03-12 at 19:41:01
; perimeters extrusion width = 0.40mm
; infill extrusion width = 0.67mm
; solid infill extrusion width = 0.67mm
; top infill extrusion width = 0.67mm
G21 ; set units to millimeters
M190 S70 ; wait for bed temperature to be reached
M104 S230 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
M109 S230 ; wait for temperature to be reached
G90 ; use absolute coordinates
G92 E0
M82 ; use absolute distances for extrusion
M106 S255
G1 F1800.000 E-1.00000
G92 E0
G1 Z0.200 F9000.000
G1 X90.037 Y89.394 F9000.000
G1 E1.00000 F1800.000
G1 X92.500 Y88.536 E1.06972 F3240.000
G1 X107.500 Y88.536 E1.47067
G1 X309.225 Y288.931 E1.51797
G1 X310.606 Y290.037 E1.56527 F3240.000
G1 X311.464 Y292.500 E1.63499
G1 X311.464 Y307.500 E2.03593
G1 X311.069 Y309.225 E2.08323
G1 X309.963 Y310.606 E2.13053
G1 X307.500 Y311.464 E2.20026
G1 X292.500 Y311.464 E2.60120
G1 X290.775 Y311.069 E2.64850
G1 X289.394 Y309.963 E2.69580
G1 X288.536 Y307.500 E2.76552
G1 X288.536 Y292.500 E3.16647
G1 X288.931 Y290.775 E3.21377
G1 X289.999 Y289.441 E3.25946
G1 X290.300 Y289.618 F9000.000
G1 X290.350 Y289.559 E3.26151 F3240.0
I'm sure its one small detail that i missed in configuration but i cant figure it out and its been driving me nuts for the last few days. Thanks
-Eric
Re: Prusa I3 wont print on bed
March 13, 2015 02:23AM
Have you set up your bedsize and the center of the bed in slic3r?
March 13, 2015 06:27AM
bed size is set to 200 x200 in slic3r and has 100 1000 as center and it still gives the wrong gcode
sorry 100 100 not 100 1000
March 13, 2015 01:31PM
Check you tool offsets in both slicer and firmware.
March 13, 2015 01:59PM
ebmoney08
-Eric
I had this exact same problem. Are you using RH to setup? I can tell you where you mistake probably is...
March 13, 2015 03:14PM
Yes I am. What was it?
March 13, 2015 03:57PM
If you're using the Folger guide to set up the print then flip to page 12 in the configuration manual about setting up the Printer Settings in RH. Under the "Printer Shape" or "Dimensions" tab I'd bet one of your values is in the wrong place. Make sure your Xmin, Xmax, Ymin, and Ymax are all correct, min should be 0, max should be 200. Bed left and front should be 0. Print area width and depth should be 200 and height should be 185. I attached a screenshot of the page in the manual if this doesn't make sense.
open | download - Screen Shot 2015-03-13 at 2.35.35 PM.png (69.9 KB)
March 13, 2015 04:16PM
I'm not home right now but I'm pretty sure my bed front and bed left values are wrong. I think folger techs config manual is wrong. Thanks. I'll let you know if it works.
March 13, 2015 04:24PM
ebmoney08
Do let me know. I built my Prusa i3 from FolgerTech about 2 or 3 weeks ago, my values were also wrong, I believe the manual FolgerTech provides on their Google Drive is an older one, however, a member of this forum, MakerFront, is the author of the manuals and has updated ones in his signature if you'd like to take a look through them.
Edit:
Here's the link to the manuals, so you don't have to go search for him.
[drive.google.com]
Edited 2 time(s). Last edit at 03/13/2015 04:31PM by widespreaddeadhead.
March 14, 2015 02:08PM
You were right. I got it to work last night. Thanks for the help. It was driving me nuts.
March 14, 2015 09:25PM
ebmoney08
I had the same problem. Glad to help.
March 20, 2015 12:33AM
Hi Guys,
I have the same problem. But it was not solved by configuring as told.
Any other thing have you done???
Thanks.
