Molten piece March 16, 2015 03:13AM |
Re: Molten piece March 16, 2015 03:32AM |
Re: Molten piece March 16, 2015 06:33AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Molten piece March 16, 2015 10:32AM |
waitaki
Why do you have a joiner in there in the first place? The heated bed should have one continuous cable from from the bed terminals to the Ramps connector post.
Re: Molten piece March 16, 2015 10:43AM |
Dust
you bed uses 11 amps. that looks like a 5amp screw terminal
either that or it wasnt screwed down very hard at it was heating up due to the bad connection.
Re: Molten piece March 16, 2015 11:20AM |
Re: Molten piece March 17, 2015 02:52AM |
SupraGuy
It comes down to this: all conductors are also resistors, and resistors are heaters.
That terminal was higher resistance than the wire, so it got hot while conducting power. Look at your heat bed, there are no components on it (Other than the diodes and LEDs) it's just trace wires, which we'd normally consider to have no resistance, but because they're thin, and log, they do, so when we run a lot of power through them, they get hot. Quite often, the wires that come with kits (The ones in my kit certainly were) are quite thin, just barely enough to manage the power that we're running through them, so the wires will often get very warm or hot as is. Extending these to be longer isn't a really good idea, I'd recommend de-soldering the existing wires, and solder on wires of a heavier gauge and appropriate length for your application, Your heat bed will get hot faster, and you'll reduce your risk of a fire.
Re: Molten piece March 17, 2015 11:28AM |
Re: Molten piece March 18, 2015 05:15AM |
Re: Molten piece March 21, 2015 02:16PM |
