What Prusa i3 Derivate should I pick?
Posted by mikes3ds
March 20, 2015 03:23PM
Hello all, I have been looking around for what is the best Prusa i3 Derivate. (I have access to a laser cutter and a 3D printer.)
Or should I go with the original prusa i3.
So many options, I really need help figuring out what one is the best that I can use a laser cutter to make the frame.
Thanks
(Edit laser cutter)
Edited 3 time(s). Last edit at 03/20/2015 05:21PM by mikes3ds.
Re: What Prusa i3 Derivate should I pick?
March 20, 2015 04:21PM
Laser cutter or laser printer ?
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
March 20, 2015 04:54PM
Laser cutter. epilog 60 watt laser cutter/engraver
March 20, 2015 05:45PM
Well, I like the way the Mendel90 is engineered. To me it overtakes the I3. Don't cut an acrylic frame. Acrylic is rubbish. Use the thicker mdf your laser is able to cut. The thicker, the better. The mobile parts needs to be light, but the fixed parts are better if they're heavy.
