Bed adhesion on long prints March 29, 2015 09:43PM |
Re: Bed adhesion on long prints March 30, 2015 01:29AM |
Re: Bed adhesion on long prints March 30, 2015 11:05PM |
Re: Bed adhesion on long prints March 30, 2015 11:52PM |
Re: Bed adhesion on long prints March 31, 2015 05:39AM |
Re: Bed adhesion on long prints April 06, 2015 11:55PM |
Re: Bed adhesion on long prints April 07, 2015 07:37AM |
Re: Bed adhesion on long prints April 09, 2015 04:02AM |
Re: Bed adhesion on long prints April 09, 2015 04:01PM |
Re: Bed adhesion on long prints April 10, 2015 02:19PM |
Re: Bed adhesion on long prints April 11, 2015 06:29PM |
Re: Bed adhesion on long prints April 17, 2015 05:42AM |
Re: Bed adhesion on long prints April 17, 2015 06:36AM |
rich you hit on the head.Quote
rich1812
It happened to me as well. I found that keeping the bed temp lower (I keep it around 65-70C, seems to help, also I applied a thick even coat of hair spray on a clean bed, wait for it to dry, , then before I print I spray more on the corners where it's likely to buckle so the corners stick better. Also babysit your print, press down the corners once so often before it starts to buckle. It works for me. Hope this helps.
Re: Bed adhesion on long prints April 17, 2015 06:47AM |
i don't use blue tape so i can tell you. but my 3cent is on clean glass two lite layer of hair spray when bed is cold let dry. start heating bed stray little more on bed. leave the heat on the hold time you print. PLA 60 to 75 in ABS around 100. let me know that works.Quote
RiaanLR
I am also having this problem. Printing on blue painters tape. Sits great for small prints but the longers ones come lose on the edges.
ABS, 3mm, nozzle .4mm, layer thickness.3mm, all layers .3mm,
Printing slow at 30mm/sec for the bottom layers.
Should i bring down the bed heat or increase after the first layers. current temp 100 degrees for complete print.
Riaan
