Two slic3r controlled fans March 30, 2015 04:57PM |
Re: Two slic3r controlled fans April 02, 2015 04:47AM |
Re: Two slic3r controlled fans April 02, 2015 08:25AM |
Re: Two slic3r controlled fans April 24, 2015 07:46PM |
#define FAN_PIN 8would I simply add
#define FAN_PIN 6(the fan pin i'd like to use for a secondary fan)?
#if FAN_PIN > -1 if (FanSpeed != 0){ analogWrite(FAN_PIN,FanSpeed); // If buffer is empty use current fan speed } #endif } if((DISABLE_X) && (x_active == 0)) disable_x(); if((DISABLE_Y) && (y_active == 0)) disable_y(); if((DISABLE_Z) && (z_active == 0)) disable_z(); if((DISABLE_E) && (e_active == 0)) { disable_e0(); disable_e1(); disable_e2(); } #if FAN_PIN > -1 if((FanSpeed == 0) && (fan_speed ==0)) { analogWrite(FAN_PIN, 0); } if (FanSpeed != 0 && tail_fan_speed !=0) { analogWrite(FAN_PIN,tail_fan_speed); } #endif
Re: Two slic3r controlled fans April 24, 2015 08:02PM |
#define FAN2_PIN 6below your motherboard definition (Rambo)
#if MOTHERBOARD == 301 #define KNOWN_BOARDDo NOT redefine FAN_PIN. Leave it alone.
#define EXTRUDER_0_AUTO_FAN_PIN -1and change it to
#define EXTRUDER_0_AUTO_FAN_PIN FAN2_PIN
Re: Two slic3r controlled fans April 24, 2015 08:08PM |
#define EXTRUDER_0_AUTO_FAN_PIN -1I believe I must have an older version of the firmware. Marlin_15 is what the filename is. I have an Airwolf 3D XL.
Re: Two slic3r controlled fans April 24, 2015 08:13PM |
Re: Two slic3r controlled fans April 24, 2015 08:21PM |
Re: Two slic3r controlled fans April 24, 2015 08:30PM |
Re: Two slic3r controlled fans April 24, 2015 08:34PM |
Re: Two slic3r controlled fans April 25, 2015 06:56AM |
Re: Two slic3r controlled fans April 27, 2015 02:36PM |
Re: Two slic3r controlled fans April 27, 2015 05:05PM |
sventizzle
I think I may need to adjust the motor stepper values on the X and Y due to some not perfectly straight vertical walls on the 20mm test cube. I read somewhere that someone experienced a similar situation after changing to a different head.
Could the difference in weight of the print head cause such a discrepancy?
You are welcomeQuote
sventizzle
Thanks for your help Hakimio.
