darwin dc motor won't turn June 15, 2010 06:22PM |
Re: darwin dc motor won't turn June 20, 2010 03:21PM |
Re: darwin dc motor won't turn June 20, 2010 03:29PM |
Re: darwin dc motor won't turn June 22, 2010 02:12PM |
Re: darwin dc motor won't turn June 22, 2010 02:32PM |
Re: darwin dc motor won't turn June 22, 2010 02:56PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: darwin dc motor won't turn June 22, 2010 03:40PM |
Re: darwin dc motor won't turn June 22, 2010 04:12PM |
Re: darwin dc motor won't turn June 23, 2010 04:25AM |
Re: darwin dc motor won't turn June 26, 2010 02:49PM |
Re: darwin dc motor won't turn June 26, 2010 03:26PM |
Re: darwin dc motor won't turn June 26, 2010 04:13PM |
Re: darwin dc motor won't turn June 26, 2010 04:54PM |
Re: darwin dc motor won't turn June 27, 2010 11:42AM |
void extruder::set_speed(float sp) { e_speed = (byte)sp; if(e_speed > 0) //wait_for_temperature(); analogWrite(motor_speed_pin, e_speed); //analogWrite(motor_speed_pin, e_speed); return; }
Request: 27/06/2010 18:22:12.26364 (+0.0000 seconds) 47 31 20 46 33 30 30 30 2E 30 0A G1 F3000.0. Answer: 27/06/2010 18:22:12.26364 (+0.0000 seconds) 0A 6F 6B 0D .ok. Request: 27/06/2010 18:22:12.29564 (+0.0000 seconds) 47 31 20 45 31 38 2E 33 0A G1 E18.3. Answer: 27/06/2010 18:22:12.29564 (+0.0000 seconds) 0A 6F 6B 0D .ok. Request: 27/06/2010 18:22:12.32664 (+0.0000 seconds) 47 31 20 46 31 35 30 30 2E 30 0A G1 F1500.0. Answer: 27/06/2010 18:22:12.32664 (+0.0000 seconds) 0A 6F 6B 0D .ok.
Request: G1 F3000.0. Answer: .ok. Request: G1 E18.3. Answer: .ok. Request: G1 F1500.0. Answer: .ok.
//turn extruder on, forward case 101: ex[extruder_in_use]->set_direction(1); ex[extruder_in_use]->set_speed(extruder_speed); break; //turn extruder on, reverse case 102: ex[extruder_in_use]->set_direction(0); ex[extruder_in_use]->set_speed(extruder_speed); break;And try as I might, I can not find a place where the code interperts a command like G1 E***
Re: darwin dc motor won't turn June 27, 2010 12:15PM |
void extruder::set_speed(float sp) { e_speed = (byte)sp; if(e_speed > 0) analogWrite(motor_speed_pin, e_speed); //analogWrite(motor_speed_pin, e_speed); return; }
Re: darwin dc motor won't turn June 27, 2010 12:28PM |
Re: darwin dc motor won't turn June 27, 2010 12:42PM |
Re: darwin dc motor won't turn June 27, 2010 01:27PM |
Re: darwin dc motor won't turn June 27, 2010 01:59PM |
Re: darwin dc motor won't turn June 27, 2010 02:15PM |
Re: darwin dc motor won't turn June 27, 2010 10:15PM |
Admin Registered: 16 years ago Posts: 476 |
Re: darwin dc motor won't turn June 28, 2010 05:12AM |
Jonathan
I hope this helps explain what you have discovered "the hard way"
Re: darwin dc motor won't turn June 28, 2010 06:31AM |
Re: darwin dc motor won't turn June 28, 2010 06:50AM |
