Multiple object in one code file with Sli3r April 08, 2015 07:47PM |
Re: Multiple object in one code file with Sli3r April 08, 2015 08:44PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Multiple object in one code file with Sli3r April 08, 2015 09:06PM |
Re: Multiple object in one code file with Sli3r April 08, 2015 09:34PM |
Re: Multiple object in one code file with Sli3r April 08, 2015 11:12PM |
I am not concern with collision as the parts are < 5mm and they are all similar.Quote
Dust
That add in so many complexities...
That wold mean the highest thing you could print would be no higher than than length of your hot end. or the rest of the machine will hit and break the exsisting print. less of an issue with deltas, but the software would still need to know the size of you effector to space the parts wide enough aprt to they dont get hit..
Duh! I thought I saw this option before, but never connected the dots. I am wondering why you said it will produce inferior result tho unless you meant collisions?Quote
IMBoring25
Slic3r does have this functionality, in Print Settings --> Output Options. There's a Sequential Printing section with a Complete individual objects checkbox and dimensions for the size of your print head.
In addition to the risk of collisions with previously-printed parts (which properly setting the print head clearance dimensions should mitigate) note also that the print is likely to take longer this way and may produce inferior results, especially if the parts are small.
The only one I have used is Sli3r. The reason I want to do this is precisely what you said, I can have all parts on one bed and print, then go do something else, serval hours later I come back, all parts are served.Quote
jculver09
I am not that experienced with slic3r, but I have seen these options in Cura, Tools tab at the top allows you to select all at once or one for one. You then go into machine>machine settings and you can setup the geometry of your head so that it doesn't crash. I have never used it, so that's about all i have for you.
I have always printed the entire sheet one slice at a time (regardless of how many parts are on it). I thought everyone did it this way unless there was some highly specific need (although I cannot think of any). My approach has always been, if I need 1 part quick, print just that part, if I need a bunch of parts, set it up and let it do its thing while I do something else.
Re: Multiple object in one code file with Sli3r April 09, 2015 12:53AM |
Re: Multiple object in one code file with Sli3r April 09, 2015 02:14AM |
rich1812
