I've made some proof of concept for the Zach's concept:
"simply print your design on a sheet of paper, attach it to the board you intend to cut, the cut where it indicates on the paper. if you glue it on somehow, then you're set!"
I've took the Darwin Y carriage and tried to make it easier to make with a drill press and a saw. I took some liberties on the dimensions however.
Tell me any improvements that could be made on these files.
The PDF of the drawings:
bf5man.googlepages.com]
