LCD CONTROLLER BEHAVING CRAZY
April 13, 2015 01:29AM
Hello All,
My Reprap Discount Smart Controller installed along with RAMPS, behaves crazy.
If I control the Printer with Proterface, It works fine, But When I try to control via LCD Controller, the Z Axis acceleration is too high and it behaves crazy.
Im not sure, whether its LCD issue or some firmware values with the LCD part. I did used a similar controller in my past machine and it worked better. this time its really crazy.
Im using marlin, and any help shall be highly appreciated.
Regards,
Pingnagan P
Re: LCD CONTROLLER BEHAVING CRAZY
April 13, 2015 01:40AM
The z vmax in pronterface is set differently from the printer vmax setting. You may be able to set it using the lcd if eeprom is enabled in firmware. You didn't mention the type of printer or firmware so can't be more specific.
April 13, 2015 03:37AM
Thanks for the reply.
Its a custom designed Prusa i3 Style Cartesian Printer and using the Marlin Firmware.
Yes I did enabled the EEPROM . Where Can we change them, or even find the exact value of the Pronterface.
April 13, 2015 06:46AM
You can find the Z offset here:
In the menu => control => motion => Vmax z.
Make sure you store settings in control => Store memory to make it permanent.
Edited 2 time(s). Last edit at 04/13/2015 06:48AM by imqqmi.
April 13, 2015 12:16PM
Thanks a lot all
Excellent imqqmi
It worked, and I could only reduce it to value 1, while the X, Y is 0.
Edited 1 time(s). Last edit at 04/13/2015 12:17PM by pingnagan.
