Temperature readings from thermistors built in to silicone heaters April 17, 2015 03:32PM |
Re: Temperature readings from thermistors built in to silicone heaters April 19, 2015 09:09AM |
Re: Temperature readings from thermistors built in to silicone heaters April 19, 2015 09:26AM |
neildarlow
Where is the heated bed's thermistor located? Between silicon pad and aluminium sheet or between aluminium sheet and glass?
Re: Temperature readings from thermistors built in to silicone heaters April 19, 2015 02:02PM |
dc42
neildarlow
Neither, it's buried within the silicone. I am using a 300mm diameter heater with a 330mm alu plate to allow space for bed clips and mounting screws, so some drop off in temperature towards the edge of the 300mm printable area is understandable.
I find that getting good temperature readings on top of an insulating surface like glass is difficult. The glass doesn't conduct heat to the thermocouple well, and the thermocouple wires conduct heat away from the bead.
I finally got good ABS prints by commanding the bed to 140C. This gave a reading on the thermocouple of around 100C on top of the glass, and 120C between the bottom of the heater and the cardboard insulation underneath the heater. So I think part of the problem is that the thermistor is seeing something close to the element temperature, which is about 20C more than the temperature of the alu plate, and I am losing another 20C across the 4mm glass.
Re: Temperature readings from thermistors built in to silicone heaters April 19, 2015 02:24PM |
Re: Temperature readings from thermistors built in to silicone heaters April 19, 2015 02:28PM |
Re: Temperature readings from thermistors built in to silicone heaters April 19, 2015 02:36PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Temperature readings from thermistors built in to silicone heaters April 19, 2015 02:37PM |
