LCD DISPLAY GARBAGE
Posted by pingnagan
LCD DISPLAY GARBAGE
April 18, 2015 02:57PM
Fellow Reprappers,
Im having issue with my LCD - Reprap Discount Smart Controller, displying garbage and after a single click comes back , this happens every now and then.
Is there a way to fix this permanently.
Attached pic for reference.
Any help shall be much appreciated.
Regards,
Pingnagan P
open | download - LCD_ERR.jpg (84.6 KB)
Re: LCD DISPLAY GARBAGE
April 18, 2015 03:10PM
I've seen this caused by static discharge. Try grounding the frame of the printer, and try to touch the grounded frame before adjusting anything with the encoder.
It could be a cable problem- try swapping the two cables to see if the problem remains, changes, or goes away.
April 18, 2015 03:12PM
It makes sense, Let me try and update on Grounding the Printer.
April 18, 2015 06:59PM
It also has happened in the past when someone extends the cables beyond their original length. My 12864 graphical LCD throws garbage at times because the on-board 5V power supply from the Azteeg X5 Mini is a little bit weak, and I have to run it from USB power to have the GLCD work reliably.....
April 18, 2015 10:59PM
Those display modules use SPI to communicate with the controller board and long cables cause them to lose sync. I think the cables should be kept under 300mm.
April 19, 2015 12:33PM
I use the short original Cable, not any extensions specifically.
