Ormerod 2 bed plane compensation/G30 issue April 18, 2015 05:04PM |
Command | Reported | Actual | Accumulated difference ======================================================================== | 0,0 | 0,0 | 0,0 G1 X50 Y5 F2000 | 50,5 | 50,5 | 0,0 G30 P0 Z-100000 | 45,4 | 50,5 | 5,1 G1 X50 Y180 F2000 | 50,180 | 55,181 | 5,1 G30 P1 Z-100000 | 45,179 | 55,181 | 10,2 G1 X212 Y180 F2000 | 212,180 | 222,182 | 10,2 G30 P2 Z-100000 | 207,179 | 222,182 | 15,3 G1 X212 Y5 F2000 | 212,5 | 227,8 | 15,3 G30 P3 S Z-100000 | 207,4 | 227,8 | 20,4 G1 X0 Y0 | 0,0 | 20,4
M561 G1 Z10 F200 G1 X50 Y5 F2000 G30 P0 Z-100000 G1 Z10 F200 G1 X50 Y180 F2000 G30 P1 Z-100000 G1 Z10 F200 G1 X212 Y180 F2000 G30 P2 Z-100000 G1 Z10 F200 G1 X212 Y5 F2000 G30 P3 S Z-100000 G4 P1500 ; Leave the probe there to give the web interface time to report the plane points G1 Z10 F200
Re: Ormerod 2 bed plane compensation/G30 issue April 23, 2015 05:44AM |
Re: Ormerod 2 bed plane compensation/G30 issue April 23, 2015 07:52AM |
Re: Ormerod 2 bed plane compensation/G30 issue April 23, 2015 10:34AM |
Re: Ormerod 2 bed plane compensation/G30 issue April 24, 2015 04:11AM |
; Configuration file for RepRap Ormerod 2 ; RepRapPro Ltd ; ; Copy this file to config.g if you have an Ormerod 2 ; If you are updating a config.g that you already have you ; may wish to go through it and this file checking what you ; want to keep from your old file. ; M111 S0 ; Debug off M550 PMy RepRapPro Ormerod 2 ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address M552 P192.168.1.80 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.1.254 ; Gateway M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute corrdinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z800 E800 ; Set motor currents (mA) M305 P0 R4700 ; Set the heated bed thermistor series resistor to 4K7 M305 P1 R4700 ; Set the hot end thermistor series resistor to 4K7 M569 P0 S0 ; Reverse the X motor M92 E429 ; Set extruder steps per mm M558 P2 ; Use a modulated Z probe G31 Z3.2 P595 ; Set the probe height and threshold M556 S79 X0 Y0 Z0 ; Put your axis compensation here M201 X500 Y500 Z15 E500 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X200 Y200 Z30 E20 ; Minimum speeds mm/minute M563 P0 D0 H1 ; Define tool 0 G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures ;M563 P1 D1 H2 ; Define tool 1 Uncomment if you have a dual colour upgrade ;G10 P1 X19 S-273 R-273 ; Set tool 1 operating and standby temperatures ;Uncomment if you have a dual colour upgrade
Re: Ormerod 2 bed plane compensation/G30 issue April 24, 2015 04:24AM |
Re: Ormerod 2 bed plane compensation/G30 issue April 24, 2015 05:46AM |
bartdietrich
Given that the new firmware with this bug fixed (1.09) will be released early next week, should I just wait until then before redoing all calibration steps? Is switching to dc42's firmware considered cheating on RepRap and result in Ian no longer talking to me? :-)
In the meantime, if I want to try printing stuff, the printer seems to work well enough without ever running bed.g.
Thanks,
Bart
Re: Ormerod 2 bed plane compensation/G30 issue December 02, 2015 10:03AM |
