Prusa I3 Z motors not moving April 19, 2015 10:14PM |
Re: Prusa I3 Z motors not moving April 20, 2015 09:41AM |
Re: Prusa I3 Z motors not moving April 20, 2015 10:11AM |
Re: Prusa I3 Z motors not moving April 20, 2015 01:27PM |
Re: Prusa I3 Z motors not moving April 20, 2015 03:20PM |
Re: Prusa I3 Z motors not moving April 21, 2015 09:13PM |
Re: Prusa I3 Z motors not moving April 21, 2015 09:16PM |
psneddon
You stated that you checked each motor by connecting them to the X axis connector on the Ramps board and it still wouldn't turn? I assume you were using Pronterface to turn the X-axis motor with the Z-axis motor connected to the X-axis connector on the Ramps board.
Are you sure you have the wiring right on the Z axis motors? That's where I would start if the motors won't turn when hooked up to a known good driver connection.
Re: Prusa I3 Z motors not moving April 22, 2015 09:17AM |
Re: Prusa I3 Z motors not moving April 23, 2015 12:57PM |
Re: Prusa I3 Z motors not moving April 25, 2015 12:05AM |
psneddon
If you find out what the problem was, please post your solution. Thanks.
Re: Prusa I3 Z motors not moving April 27, 2015 12:00PM |
Re: Prusa I3 Z motors not moving January 07, 2016 08:38PM |
Re: Prusa I3 Z motors not moving January 07, 2016 10:27PM |
Re: Prusa I3 Z motors not moving January 07, 2016 10:50PM |
Re: Prusa I3 Z motors not moving January 08, 2016 02:14AM |
Re: Prusa I3 Z motors not moving January 08, 2016 02:38PM |
Re: Prusa I3 Z motors not moving January 08, 2016 02:43PM |
Re: Prusa I3 Z motors not moving January 08, 2016 07:16PM |
