MK8 extruder clicking April 27, 2015 03:30PM |
Re: MK8 extruder clicking April 29, 2015 01:03AM |
Re: MK8 extruder clicking April 29, 2015 12:42PM |
I have this problem too. I can feel the clicking when I touch the filament. For a while it didn't seem to matter on my prints, but I had one fail recently and my hotend clogged so here is my far from expert opinion:Quote
Vanbot
OK could this be caused by the hot end not melting filament fast enough to keep up with the drive gear? That is, my drive gear speed is set a little fast? It only does it occasionally so if it was extruder feed set too fast wouldn't it click all the time?
Anyone else with a Folger i3 have this issue? I'm using all of their settings, including feed speed.
Re: MK8 extruder clicking April 29, 2015 12:52PM |
widespreaddeadhead
Vanbot
I believe it's happening because the bed is too close to the nozzle, which might be do to warped acrylic the heated bed sits on, a not totally level glass bed, leveling a cool bed and then printing on it heated and not taking into account the glass expansion, etc.. The extruder is pushing filament down to close to the bed and some of it stays in the nozzle, then the extruder is trying to push the same amount of filament out constantly, while some is still getting caught up in the nozzle.
Not sure if that correct or applies to you, but I believe this is my problem and now I have a seriously clogged nozzle
Re: MK8 extruder clicking April 29, 2015 12:53PM |
Re: MK8 extruder clicking April 29, 2015 01:25PM |
Re: MK8 extruder clicking April 29, 2015 01:38PM |
Vanbot
I've wondered about this at times too but I'm pretty conscientious about leveling my bed before I print.
That said, when I hold a straight edge across my heated bed it is not really even close to flat. It seems to dip in the middle by about 1 mm when I check it front to back. But since I check my bed level closer to the corners that would mean that the nozzle would be at a good distance closer to the corners and too far from the bed closer to the middle.
Re: MK8 extruder clicking April 29, 2015 01:51PM |
Re: MK8 extruder clicking April 29, 2015 02:06PM |
Re: MK8 extruder clicking April 29, 2015 04:52PM |
widespreaddeadhead
The hotend they supply isn't very reliable. I've heard and known this for a bit but was hoping to not have to drop some $$$ on a better hotend, even though no more jams would make it worth it.
Re: MK8 extruder clicking April 29, 2015 10:25PM |
widespreaddeadhead
I print on glass. Do you have any good tips for cleaning the nozzle? Acetone work well?Quote
lunarkingdom
you might try using a glass bed topper, I use one on both my printers, it is far more level than most hot beds
Re: MK8 extruder clicking April 29, 2015 10:28PM |
Vanbot
widespreaddeadhead
I assumed someone out there would have designed a geared version of this Folger extruder. The Folger kit supplies tiny 2.6 kg/cm steppers so gearing it down for more torque seems like it would be a good way to continue using those motors but with better extrusion results.
I have found this design (http://www.thingiverse.com/thing:239085/#instructions) which is for a geared version but it uses a grooved drive gear while the drive gear I got from Folger is flat. It also seems like it might be a bowden-based design which I don't want to get into if I don't have to.
Re: MK8 extruder clicking April 30, 2015 01:05PM |
You will always have jams without an E3D style of hotend
Re: MK8 extruder clicking April 30, 2015 08:20PM |
Re: MK8 extruder clicking May 01, 2015 02:40AM |
Vanbot
This is the extruder that Folger supplies. Is it even a true MK8? Don't MK8 extruders have a spring loaded idler?
Re: MK8 extruder clicking May 01, 2015 10:52AM |
Re: MK8 extruder clicking May 01, 2015 11:28AM |
Re: MK8 extruder clicking May 01, 2015 12:38PM |
Re: MK8 extruder clicking May 01, 2015 11:09PM |
