Linux or Windows For Slic3r
April 28, 2015 08:56PM
I was having Stability issue while running Slicr3r
Crashes on some STL files
Crash more if more config are saved
Crash in Windows 7 or 8
Crash on 3 diferent PC
Ive try for fun Running Slicr3r In a VirtualBox VM , under Ubuntu
Never crashes , and render time is half the time it was before
Guess is wasn't intended to run in windows at first !
Any other one got similar result or Experiences ?
Re: Linux or Windows For Slic3r
April 28, 2015 09:11PM
tijeff
I run Slicer as part of the Repetier package on Win 8.1 with no issues. Slicer is the least of my worries. :-)
April 29, 2015 12:24AM
I have found Slic3r to be unstable- when it works it's great, when it doesn't it's a PITA. I have also found that it seems to work most reliably when you compile the source code under linux.
April 30, 2015 04:41PM
I ran it on an old Netbook running both Linux and Win7 at different times. As long as the STL was manifold (?), the only issue I ever had was the crappy Netbook.
May 01, 2015 11:17PM
Precompiled package works great on Arch Linux; the self-compiled one doesn't start at all.
Edited 1 time(s). Last edit at 05/01/2015 11:17PM by epicepee.
