Please Please Help - Problem with Power Supply - SOLVED May 02, 2015 01:31PM |
Re: Please Please Help May 02, 2015 07:11PM |
Re: Please Please Help May 02, 2015 07:47PM |
Okay, I did have a multimeter, and I found that the 120v are going in just fine, but none of the 12v outlets are working. Then, I found that as I was fumbling around, it worked. Next, I unplugged it, and plugged it back in. It didn't work. I then hit it, and it did. After unplugging it and plugging it back in, nothing seems to work. I will say that around 23v were coming out of it, but it says it's supposed to output 12v. I included a picture of the inside. If you have any ideas, let me know.Quote
blabbersnitch
Hello again.
I must admit, it's fun trying to sort out problems when they're not my own ;-)
I wonder if you have a multimeter? You can get a pretty good one for not much money nowadays. If you don't have one, get one. It will be indispensable in sorting out these problems (and setting up stepper motors etc).
If you do have one, Have you checked the output of the supply? Is it zero, or something else? I would disconnect the cables at the output of the supply to see if the problem is with the power supply or what it is driving. Of course, check the voltage at the input terminals of the power supply, just in case you did something dumb like terminate onto the wire's insulation instead of the bare strands, or if the mains is missing or sick.
Re: Please Please Help May 02, 2015 07:49PM |
Re: Please Please Help - Problem with Power Supply - SOLVED May 03, 2015 01:03AM |
Admin Registered: 16 years ago Posts: 730 |
Thank you very much for posting the solution to the problem. This adds value to the forum and it will help people in the future who might have a similar problem. Note: I edited the subject line of your original post so that it is more descriptive of the problem.
Re: Please Please Help - Problem with Power Supply - SOLVED May 03, 2015 01:23AM |
Great thank you. I hope it does help someone some day. Just make 100% sure that the power isn't plugged in when you do this and you know what you are doing. This can kill you.Quote
MattMoses
Hi fatesalign, I'm glad you got it working.Thank you very much for posting the solution to the problem. This adds value to the forum and it will help people in the future who might have a similar problem. Note: I edited the subject line of your original post so that it is more descriptive of the problem.
