X axis mounts uneven May 17, 2015 01:21AM |
Re: X axis mounts uneven May 17, 2015 11:23AM |
Re: X axis mounts uneven May 17, 2015 11:54AM |
Re: X axis mounts uneven May 17, 2015 01:45PM |
Re: X axis mounts uneven May 17, 2015 07:26PM |
Re: X axis mounts uneven May 17, 2015 08:07PM |
Re: X axis mounts uneven May 17, 2015 08:38PM |
Re: X axis mounts uneven May 18, 2015 01:00AM |
Re: X axis mounts uneven May 18, 2015 01:10AM |
Re: X axis mounts uneven May 18, 2015 03:10AM |
the_digital_dentist
Printing a rectangle shows you how the axes are aligned. If they are not orthogonal, the diagonals won't match. There is nothing you can do in Cura to compensate, though theoretically corrections could be applied in software.
Re: X axis mounts uneven May 18, 2015 07:29AM |
Re: X axis mounts uneven May 18, 2015 08:51AM |
the_digital_dentist
That's very interesting! How does it work? What does it use for input?
Re: X axis mounts uneven May 18, 2015 11:39AM |
Re: X axis mounts uneven May 18, 2015 12:24PM |
the_digital_dentist
Interesting, but it assumes that the axes will all be static- i.e. the X axis alignment isn't going to change. If you have a problem like the OPs, where the axis keeps tilting, the compensation won't work unless you keep redoing the test print and measurements.
I think it's still best to align the axes to be orthogonal and lock them down so they can't move- which generally means a single motor to drive as many screws as lift the X axis or the bed. It saves a lot of time and screwing around later.
