DVR8825 microstep jumper setting don't register
Posted by sungod3k
May 17, 2015 09:52PM
I have used the DVR 8825 for some time now and they worked well on 1/32 setting. Now I wanted to save some calculation power on the chip and go back to 1/16.
I looked up the jumper settings here set only the jumper furthest away from the bladefuses (m3/ mode2). Then I halved the steps in the firmware, but now all movement come 50% to short. It is as the board still expects 1/32 steps with 50% reduced steps.
Any ideas?
Re: DVR8825 microstep jumper setting don't register
May 18, 2015 03:53AM
I´ve read rumors about some cloned RAMPS boards, that have bridges on the PCB between the jumperpins. (stupid )
No matter, if the jumper is there or not, it will stay in 1/32 until you cut the bridge on the PCB.
Calculation time is no issue between 1/16 and 1/32. It is just one register shift more or less smiling smiley
-Olaf
May 18, 2015 04:26AM
ah yes I remeber reading something like this a long time ago. Its a chinese board so thats a possibility Ill check it out.
May 18, 2015 06:07AM
Have you done what I did?
that is - change the jumpers, changed the config.h but . . .
Forgot to update eeprom settings from the firmware ( M502, M500) ?
-a
May 18, 2015 06:21AM
Yes hardcoded setting are loaded.
