Wade Extruder Question
May 23, 2015 06:06PM
Hello, I purchased a wade extruder from Maker Geeks, and I got the set with the screws/nuts etc, but I can't find the center bolt in this pic:
Here is the kit: [www.makergeeks.com]
It shows everything I have, but it doesn't show that one part, so what should I use?
Edited 1 time(s). Last edit at 05/23/2015 06:26PM by fatesalign.
Re: Wade Extruder Question
May 23, 2015 06:55PM
I believe that would be a 8mm diameter by 20mm long piece of threaded shaft. It does not need to be threaded, if you have some left over 8mm smooth rod it would work just as well.
