Heatbed stalls @ 92c
Posted by elwood127
May 29, 2015 01:43AM
Out of the blue my temp fluxuates between 90 and 92 when set to 100c. Used to go where ever I asked it. Power supply tanking? Melzi board dieing? It's the latest version. Abs not wanting to stick as well. Plexiglass I3. Thanks.
Re: Heatbed stalls @ 92c
May 29, 2015 01:53AM
Now it's up to 97. Took about 15 minutes to gain 5 degrees.
Edited 1 time(s). Last edit at 05/29/2015 01:54AM by elwood127.
May 29, 2015 02:16AM
Hey I'm up to 100 but took forever.
May 29, 2015 02:27AM
Bad contact somewhere causing voltage drop?
When I tried to get 100° fisrt time, I raised the voltage up to 14V because I was stuck at 90°. The last 10° took about 2 mins only!
After that test, my thermistor acted weird, sending false temps intermittendly. I found, that both wires to the thermistor had become unsoldered.
-Olaf
May 29, 2015 02:37AM
Where are you adjusting the voltage? PS or control board? Thanks.
May 29, 2015 02:49AM
I have a modified meanwell 350W PS. I can crank up the voltage beyond 14V.
Unfortunately, I also use this PSU to power a 12V halogen lamp. So I have to print in the dark, when using more than 12V. eye rolling smiley
-Olaf
May 29, 2015 09:46AM
My heatbed was taking about 1 hour to reach 105 C and soon I started printing the temp was going down, replaced the wires with 14 gauge wires and in 10 minutes is already 100C.
May 29, 2015 08:53PM
Thanks guys. Off to get some bigger wire.
May 30, 2015 01:48PM
Now I have the same problem but only after I updated the marlin version, soon reaches 94C stays there and would take at least 1 hour to reach that temperature, is not the wires so has to be Marlin the problem.
May 30, 2015 11:23PM
Check your thermistor value for the heated bed in Marlin.
May 31, 2015 01:49AM
I had to change the value from 6 to 1 on my configuration file
June 01, 2015 08:06PM
Where are thermistor values being changed? Gcode?
June 01, 2015 08:22PM
No I changed the value in the config.h file
#define TEMP_SENSOR_BED 1
June 05, 2015 06:07AM
I feel like a dork. Where is that file. As in Windows/ start/ run???
June 05, 2015 10:27AM
elwood127
More like:
github/ search / Marlin smiling smiley
and
arduino.cc / download / ArduinoIDE
-Olaf
June 05, 2015 03:20PM
And it's actually Configuration.h . . . in the top of the Marlin source tree, editable with the Arduino tool kit.
So look where you chose to put Marlin, or let the tool take you to it.
- Tim
June 05, 2015 06:20PM
Thanks. I'm not using Marlin. Another question, how the heck can I print hollow. I set Slic3r to 0% infill and it keeps filling. In Cura which I prefer, there is no way to eliminate infill. Been trying to print a spiral vase but can't get it hollow. Thanks. Brian.
June 05, 2015 06:28PM
Spiral Vase requires one perimeter, 0% infill, no solid top layers, no support material, and only a single object.
More generally, Solid Infill Threshold Area may mess you up if you're printing something with small cross-sections.
June 06, 2015 03:38AM
elwood127
In Cura you have to open the expert mode and choose "black Magic" print. Don´t forget to deselect it next time, when you want infill eye rolling smiley
-Olaf
June 06, 2015 08:06PM
Thanks guys.
