extruder stops heating mid print June 12, 2015 06:26AM |
Re: extruder stops heating mid print June 12, 2015 06:48AM |
Re: extruder stops heating mid print June 12, 2015 07:46AM |
Re: extruder stops heating mid print June 12, 2015 07:53AM |
Re: extruder stops heating mid print June 12, 2015 08:34AM |
Re: extruder stops heating mid print June 12, 2015 08:35AM |
Re: extruder stops heating mid print June 12, 2015 08:37AM |
the_digital_dentist
When the extruder stops heating, does the machine stop or just keep going as if there is nothing wrong?
Did you also check connections to the heater? If the thermistor failed you'd see an error message on the LCD (if you have one), but an open heater wire wouldn't show up at all and the thing would keep trying to print while the extruder chewed a divot into the filament.
Re: extruder stops heating mid print June 12, 2015 10:04AM |
Re: extruder stops heating mid print June 12, 2015 01:27PM |
Re: extruder stops heating mid print June 12, 2015 04:36PM |
Re: extruder stops heating mid print June 14, 2015 04:42AM |
Re: extruder stops heating mid print June 16, 2015 12:31PM |
Re: extruder stops heating mid print June 17, 2015 03:12AM |
Re: extruder stops heating mid print June 17, 2015 04:05AM |
Re: extruder stops heating mid print June 19, 2015 10:56AM |
Re: extruder stops heating mid print June 19, 2015 10:58AM |
Re: extruder stops heating mid print June 19, 2015 02:27PM |
Re: extruder stops heating mid print June 19, 2015 06:54PM |
Re: extruder stops heating mid print June 19, 2015 08:41PM |
Re: extruder stops heating mid print June 20, 2015 10:24AM |
tadawson
The voltage being low by .13v will not be a problem - that is trivial, and likely due to the losd from the bed heater (which shuts off on reset). If you are seeing power on the terminals to the hot end, and it appears to stop heating, then one of two things can be going on: Either it's still hot, and the reading is wrong, or there is a fault in the heater or it's wiring.
Have you done any testing to confirm that the hot end really is cooling down? (I don't doubt you, just trying to be certain . . ). The only other thing might be to confirm that where the heater connects to the RAMPS that you don't have the insulation pushed into the connector. That could result in power on the screws, and nothing going to the heater as well.
But again, to reiterate: If you see power on the RAMPS heater terminals (even 11.87v!) and you are cooling, the problem is in the heater and it's wiring . . . Oh, and be certain to read *across* D8/D9/D10, and not to ground . . . these switch the *low* lead, and reading to ground will always show power, whether the output is actually active or not.
- Tim
Re: extruder stops heating mid print June 20, 2015 10:27AM |
blabbersnitch
I still think it's the heater (and so, I think, do most trying to help).
With power off, measure the resistance across the terminals of D10. This is the value of the resistor that is your heater. It should be five ohms give or take an ohm or two (mine is closer to six). Then print your cube, and when you see the temperature dropping, remove power and quickly take the same measurement. Either it will read about the same, indicating the heater and its associated wiring is ok, or it will read much higher indicating the heater (or its wiring) is the problem. Check what Tim suggested, I have seen it many times (the insulation in the terminal).
If it's happening at the same time during the print, then it's not random. And if it's not random, I'm guessing it's heat related. The hotend has heated up and the now the things around it are hotting up too.
I would look at the connections of the resistor to the wiring. You say you soldered them. This is the one place I didn't solder (I crimped instead). Regular solder melts at about 190 degrees and the hotend will be operating at around that temperature or even higher. The heater wires should be a bit cooler, but it was a bit close for comfort for me. Depending on what insulation you have used and how the air flows around it (and at what temperature you are operating your extruder) maybe the joints are being affected.
Eric
Re: extruder stops heating mid print June 20, 2015 10:32AM |
Re: extruder stops heating mid print June 20, 2015 11:06AM |
white
tadawson
- Tim
well i havent done any real tests that the extruder is cooling down but im using the same thermoster for the heatbed and its working fine and when i heat the extruder manually its reading fine and the temperature doesnt drop.
and i think the insulators are good because when i test the volts i put my multimeter on the wires of the heater.
and what do you mean exactly by read *accross* and switch to low ? ( im sorry im very new to this )
Re: extruder stops heating mid print June 20, 2015 11:10AM |
Re: extruder stops heating mid print June 20, 2015 12:35PM |
Re: extruder stops heating mid print June 20, 2015 02:40PM |
tadawson
Very good, just being certain . . . if you see voltage between the two D10 terminals, and have no heat, it isn't the board . . .
-Tim
Re: extruder stops heating mid print June 20, 2015 06:41PM |
Re: extruder stops heating mid print June 21, 2015 04:51AM |
blabbersnitch
Those terminations to the board look fine.
Re: extruder stops heating mid print June 21, 2015 09:45AM |
o_lampe
blabbersnitch
Veto!
You should never use soldered wires in a clamping connection. The solder tends to creep away under mech. pressure and results in a loose connection.
Re: extruder stops heating mid print June 21, 2015 10:06AM |
blabbersnitch
It's also interesting to see the MOSFETs have heatsinks on them, I haven't seen that before... but I digress.
15.3 ohms seems too high. I only have my i3 for comparison, but my heater is a 5.6 ohm resistor. That's 25 watts at 12V.
15 ohms generates less than 10 watts. When you measured the resistance, was it when the temperature was dropping, or was it when it was working fine? You need to do both.
What sort of heater is it? A resistor or cartradge (which mustbe a resistor anyway)? What hotend do you have? How is the heater secured and are you using any thermal paste?
How about a photo?
How is the resistor connected to the wires that go to the ramps board? These are the connections i was referring to when I asked if they were soldered or crimped (not the connections on the board). Take some photos of the wiring too.
Eric.
