Heat bed MOSFET (not FUSE) overheating after auto tune command June 13, 2015 05:51PM |
When I issued the auto tune command 'M303 E-1 C8 S90' to get the values for the heat bed a red LED turned on and the heat bed FUSE started to smoke
I hit the emergency stop in repetier host and switch off the power supply. |
Re: Heat bed FUSE overheating after auto tune command June 13, 2015 06:20PM |
Re: Heat bed FUSE overheating after auto tune command June 14, 2015 03:08PM |
Re: Heat bed FUSE overheating after auto tune command June 14, 2015 04:15PM |
Re: Heat bed FUSE overheating after auto tune command June 14, 2015 05:28PM |
Re: Heat bed FUSE overheating after auto tune command June 14, 2015 05:34PM |
Re: Heat bed FUSE overheating after auto tune command June 14, 2015 05:50PM |
Re: Heat bed FUSE overheating after auto tune command June 14, 2015 07:59PM |
Re: Heat bed FUSE overheating after auto tune command June 15, 2015 02:33AM |
Re: Heat bed FUSE overheating after auto tune command June 15, 2015 11:33AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 15, 2015 12:57PM |
Do you have any recommendation as where to buy the MOSFET you recommended in Europe?
Re: Heat bed FUSE overheating after auto tune command June 15, 2015 01:27PM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 15, 2015 02:25PM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 16, 2015 03:46AM |
tadawson
Once again, the red LED on the RAMPS simply means that it is turning the heater output on, and not seeing it would be a problem!
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 16, 2015 05:11AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 16, 2015 06:09AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 16, 2015 03:13PM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 17, 2015 02:16AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 17, 2015 02:42AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 17, 2015 04:16AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 17, 2015 03:07PM |
rinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 18, 2015 05:00AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 22, 2015 03:25PM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 22, 2015 04:43PM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 22, 2015 05:12PM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 22, 2015 08:50PM |
ame
The LED is also ON if the disconnected from the mega board.
Andreas
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 25, 2015 07:40AM |
rinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)|
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 25, 2015 09:36AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 25, 2015 11:49AM |
Re: Heat bed MOSFET (not FUSE) overheating after auto tune command June 25, 2015 04:03PM |
I will order a new piece and tell you when I successfully swapped it!
