Is it worth printing legos ? June 25, 2015 10:30PM |
Re: Is it worth printing legos ? June 26, 2015 12:42AM |
Re: Is it worth printing legos ? June 26, 2015 03:30AM |
Re: Is it worth printing legos ? June 26, 2015 03:31AM |
jculver09
I printed a few on my Folger Tech Delta. At .1mm layer height I am happy with the results, but even printing a dozen or more blocks at a time the time investment wouldn't be worth it for me if I were printing a large set.
Have you checked the price of legos in the stores in your area? I only needed about 10 pieces so buying a $20 set to get them is absolutely not cost effective, but that was the cheapest set that had all the pieces I was looking for so YMMV.
I have not used the 3dminions printer, but after spending the time calibrating my delta when I built it, legos print just as well as anything else and interlock with printed and regular legos well.
qiaoyifei
jculver09
OK!Thank you!I love playing lego!I will try to print a set right noew!
Re: Is it worth printing legos ? June 26, 2015 04:02AM |
Re: Is it worth printing legos ? June 26, 2015 10:28AM |
Ok,thank you,I think make lego myself is really funQuote
blabbersnitch
I have printed a few pieces.
You don't get the quality of the original Lego pieces. I would have been able to get it better with a bit of tinkering I suppose.
Where it comes in handy is if you want a Lego piece you don't have or can't get.
I made a remote control car out of Lego a few months ago. I printed the motor housing so that it was Lego compatible (see attached photo). It worked pretty well.
If I had my 3d printer then I could have tweaked it and improved it, but I was having to use a 3d printer at a Library so didn't have that flexibility.
Having said that, it fitted well enough and the whole thing worked well.
Eric
Re: Is it worth printing legos ? June 26, 2015 10:40AM |
Re: Is it worth printing legos ? June 26, 2015 10:48AM |
Re: Is it worth printing legos ? June 26, 2015 11:04AM |
thetazzbot
Take it one step further....
Think about how to design something fun like legos but 3d print friendly, that is something that is relatively quick to print but not difficult like legos.
Here are the problems with legos..
The underside needs support
The pins need to be pretty perfect to fit the next block.
They take a lonnngg time to print
There are other building block style things on thingivers that are cool. I found a triangle shape thing that snaps together and you can make geodesic shapes with it.
Be original dont just print immitations... Invent something
Re: Is it worth printing legos ? June 26, 2015 11:17AM |
Re: Is it worth printing legos ? June 26, 2015 03:20PM |
the_digital_dentist
Use Legos for what they are good for and design and print parts that are compatible for things Lego doesn't do.
Re: Is it worth printing legos ? June 27, 2015 01:25AM |
Re: Is it worth printing legos ? June 29, 2015 12:41AM |
Re: Is it worth printing legos ? June 30, 2015 02:20PM |
Re: Is it worth printing legos ? July 01, 2015 01:40AM |
Re: Is it worth printing legos ? July 02, 2015 12:01AM |
Re: Is it worth printing legos ? July 05, 2015 11:08AM |
Re: Is it worth printing legos ? July 05, 2015 11:09AM |
Can you give me the trigngles?I really want to try it.Quote
thetazzbot
Re: Is it worth printing legos ? July 06, 2015 12:57AM |
Re: Is it worth printing legos ? July 06, 2015 02:03AM |
