MK3 Heated Bed 24 Volt heating problem July 01, 2015 03:10PM |
Re: MK3 Heated Bed 24 Volt heating problem July 01, 2015 08:06PM |
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 12:40PM |
Viper97
Your heated bed is like mine. As your picture indicates the first single soldering pad is labeled on mine as #1 (in your picture, the pad on the right side). The one closest to it is labeled #2 and the furthest pad from #1 is labeled #3. So #1 is a single pad, and pads two and three are grouped together.
To wire 24V to them you would attach a +24v to pin #2 and the -24v to pin #3.
Hope this helps.
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:06PM |
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:19PM |
Viper97
It could be faulty, your power supply or the board. The 24.5v you measured was that under load? (Heat bed heating up.) 15 amps is what I've got for a 24v power supply, I'm running it at 26V out (load factor). Are you running an ac-dc relay on a RAMPS 1.4? What electronics? What wiring diagram can you put up to help troubleshoot this problem.
I have mine wired up similar to this picture however instead of 12vdc it's 24vdc and my controller is a RAMPS 1.4.
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:24PM |
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:35PM |
Viper97
Okay... what software are you running. The wiring looks okay to me so I think you're fine there. If you're using Marlin in the configuration.h there is a line of code there like this:
#define BED_MAXTEMP 150 (Mine is set to 150 so if you want you can change it to something like 115.)
If BED_MAXTEMP is less than 110 that might be part of the problem as it will cause the circuitry to cut power to the board and maintain maxtemp that you've defined. I'm not sure how Repetier does it.
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:38PM |
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:40PM |
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:49PM |
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:52PM |
AndrewBCN
Just my $0.02 here.
A simple method to check wiring, controller board, MOSFET, heatbed, etc.
1. Measure the DC voltage across the heatbed terminals when you are heating it, and measure the DC voltage across the power supply terminals too.
2. You should have approx. 24V DC at the PSU terminals, and a little bit less than that, say ~23.5V DC, across the heatbed terminals.
3. With the printer completely turned off, measure the resistance across the heatbed terminals. It should measure approx. 5~6 Ohms.
If any of these measured values do not match, it will tell you where the problem is.
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 01:54PM |
AndrewBCN
MatthijsW
I am running on marlin.
The setting i use is ( I lowered the maxtemp from the default settings):
BED_MASTEMP 120
I have changed it now to 130
I will test this right now.
Unfortunately in your case this is unlikely to change anything, and will not solve the problem.
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 02:27PM |
Viper97
My 12v system does from 22C to 45C in about 3 minutes... 30 seconds more than yours does. I've never really measured how long it takes for the 24v system to kick in but I know it's under 4 minutes to 100C... so as Andrew said (and he has far more experience at this than I) it would be good to break out the multimeter and take some measurements.
Oh and as a side note, I've got a lot of really nice Thingie collections that Andrew put up for the I3 Steel (my new printer). Thanks Andrew... appreciate the sharing of knowledge.
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 02:50PM |
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 05:31PM |
Viper97
MatthijsW
My Heated bed has a resistance of 8 Ohm.
Re: MK3 Heated Bed 24 Volt heating problem July 02, 2015 06:33PM |
AndrewBCN
Viper97
You are welcome!
MatthijsW
24V on 8 Ohms gives you 3A, and 24V x 3A = 72W which is not good enough to heat up the MK2 or MK3 heatbeds.
Conclusion: the resistance of your heatbed is out of spec by at least 30%.
Re: MK3 Heated Bed 24 Volt heating problem July 03, 2015 11:49AM |
Re: MK3 Heated Bed 24 Volt heating problem July 07, 2015 04:53PM |
MatthijsW
E3D-online.com was kind enough to send a replacement!
I will receive the heated bed next week
