Fanless power supply August 02, 2015 08:23PM |
Re: Fanless power supply August 03, 2015 01:43AM |
Re: Fanless power supply August 03, 2015 07:56AM |
Re: Fanless power supply August 05, 2015 07:34AM |
Re: Fanless power supply August 05, 2015 07:59AM |
Re: Fanless power supply August 05, 2015 09:51AM |
Im with you its stupid getting rid of safety items. I tried running mine without the fan on for a test (also looking to quiet it down) and mine got quite hot running a few hours.Quote
the_digital_dentist
While you're at it, why not replace those potentially unreliable fuses with wire jumpers?
Re: Fanless power supply August 05, 2015 09:58AM |
Re: Fanless power supply August 06, 2015 12:36PM |
Re: Fanless power supply August 06, 2015 01:25PM |
Re: Fanless power supply August 06, 2015 03:16PM |
Correct. Dont believe me then take the fan out like I did for a little and you will be very surprised how hot it gets. These PSUs need a fan.Quote
the_digital_dentist
The power brick in the photo is designed to be operated without a fan. The power supply that has a fan is designed to be operated with the fan if not all the time, when it heats up under load.
Re: Fanless power supply August 06, 2015 09:39PM |
Re: Fanless power supply August 07, 2015 07:36PM |
Re: Fanless power supply August 07, 2015 07:57PM |
Re: Fanless power supply August 10, 2015 09:24PM |
Re: Fanless power supply August 14, 2015 02:58PM |
Re: Fanless power supply August 14, 2015 09:09PM |
epicepee
You could probably get a big, quiet fan, and print a funnel adapter to cool the PSU. Or use a squirrel-cage blower at low speed.
Re: Fanless power supply August 15, 2015 12:20PM |
Re: Fanless power supply August 15, 2015 12:55PM |
Re: Fanless power supply August 15, 2015 02:38PM |
