Are there any designs out there for laser cut delta rods/arms? I currently have CF rods with traxxas rod ends, but I screwed up on some of them and the traxxas rod ends are misaligned on a few. Are laser cut rods even practical?
Did you cut them individually? Hard to mess these up. Bundle all the rods then tape both ends with masking tape or blue painters tape. I used a cut off saw with fine tooth blade but a band saw or hack saw will work. Have to put them in a vise and trim off the ends to make them even. Pretty easy
The length on them is consistent. I was not paying particular attention to the rod ends aligning with each other on either side, so two of my rods have misaligned rod ends.
Edited 1 time(s). Last edit at 08/18/2015 01:19PM by quillford.
