Your extruder flow rate looks too low, and perhaps the flow rate is not constant. Try building some simple cubes, make sure you get good smooth extrusion. Building solid parts will tell you right away if your density calculations are off - make sure you watch it carefully, as a solid part printed at too high a density will cause the head to start ploughing plastic, possibly breaking something.
Wade
