Larger print area ? September 06, 2015 04:49PM |
Re: Larger print area ? September 06, 2015 05:07PM |
Re: Larger print area ? September 06, 2015 05:27PM |
Re: Larger print area ? September 07, 2015 11:35AM |
Re: Larger print area ? September 07, 2015 11:49AM |
xelad
I just need to find a heatbed to suit. Preferably mains powered if anyone knows of any.
Alex
Re: Larger print area ? September 07, 2015 01:53PM |
Re: Larger print area ? September 07, 2015 05:29PM |
xelad
I have a big sheet of 12mm thick Lexan (polycarbonate) that i was going to recess into on my CNC machine for it. Thanks for the link i will message them right now!
Re: Larger print area ? September 07, 2015 06:10PM |
dc42
xelad
I can't imagine that you can make a heated bed out of polycarbonate. Like all plastics it is a bad conductor of heat, and even if it doesn't actually melt, the temperature gradient across it will make it warp.
Re: Larger print area ? September 07, 2015 06:30PM |
xelad
dc42
xelad
Nope i think you should do some reading on Lexan beds
Re: Larger print area ? September 08, 2015 03:32AM |
Re: Larger print area ? September 08, 2015 12:18PM |
Re: Larger print area ? September 09, 2015 05:13AM |
Re: Larger print area ? September 10, 2015 03:14AM |
dc42
- Cork sheet under the silicone heater for insulation
- Aluminium foil glued on top of the cork sheet to help reflect heat back
Re: Larger print area ? September 10, 2015 03:45AM |
etfrench
dc42
What is the max temperature you can use with cork insulation? Can it handle long print times at 130c if you're printing polycarbonate?
I'm considering using .5" to 1" of PIR under the bed, but still need to investigate a little more to make sure it can handle the temperature for long periods.
Re: Larger print area ? September 10, 2015 09:12AM |
Re: Larger print area ? September 15, 2015 08:08AM |
Re: Larger print area ? September 15, 2015 08:49AM |
Andy1989
dc42 where do you get your aluminium bed plates?
Iv got a 250mm diameter delta printer with the glass sat straight on top of a silicone heater.
If i measure the temperature at a few locations there is typically a 5 or 10 deg variation which i think an aluminium heat spreader would reduce.
Re: Larger print area ? September 15, 2015 08:57AM |
Andy1989
Re: Larger print area ? September 15, 2015 09:30AM |
Re: Larger print area ? September 15, 2015 09:52AM |
Andy1989
Thanks Doug,
I really like look of the ECOCast stuff. Its a lot cheaper than I expected too!
Re: Larger print area ? September 16, 2015 09:47AM |
Re: Larger print area ? September 16, 2015 11:32AM |
Re: Larger print area ? September 17, 2015 04:02AM |
Re: Larger print area ? October 01, 2015 10:07PM |
Re: Larger print area ? October 01, 2015 10:35PM |
Re: Larger print area ? October 02, 2015 12:40AM |
Re: Larger print area ? October 02, 2015 01:09AM |
Re: Larger print area ? October 03, 2015 08:26PM |
Re: Larger print area ? October 06, 2015 03:02AM |
Re: Larger print area ? October 06, 2015 03:15AM |
