Advice On Powering Large (450 x 450mm) Heated Bed. September 09, 2015 07:56AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 09, 2015 08:32AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 09, 2015 09:04AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 09, 2015 09:46AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 09, 2015 11:09AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 09, 2015 07:27PM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 10, 2015 03:35AM |
dc42
A simple mosfet is not suitable for switching AC mains, for two reasons: it does not provide isolation between the input and output, and it can't switch AC because in the reverse direction it conducts regardless of the gate voltage. Use a DC/AC SSR.
Be sure to take appropriate safety precautions when using AC mains. In particular:
- Any metal parts in the vicinity of mains wiring must be connected to mains ground. This includes the bed and the metal frame of your printer, assuming it has one.
- If the bed will be moving, use appropriately-rated (voltage and current) highly flexible cable to connect the bed heater to the non-moving part of the printer, and provide strain relief at both ends of the cable run. The type of cable used for multimeter tests leads should be suitable.
- Use an RCD-protected plug or socket to connect the printer to the mains.
AquaticsLive
Sure you know this part, but make sure to adjust the firmware settings for the bed heater; like in Marlin Bang bang seems to work the best unless you spend the bucks to get a super fast switching SSR.
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 10, 2015 04:10AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 21, 2015 05:40AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 21, 2015 06:32AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 21, 2015 09:31AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 21, 2015 10:41AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 22, 2015 03:55AM |
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 22, 2015 04:33AM |
xelad
Thanks for the advice! I have bought a sheet of Tufnol/Bakelite to sit between the H Frame and the silicone heater. I got the heater wired up and going last night; it heats up really really quick. It got to 110c in about 35 seconds, and considering it's size i thought that was pretty good going!
The cabling and relay stayed perfectly cool when i left it to sit at 110c for about an hour.
Heres the next question, the bed is super powerful and usually overshoots its target temp by about 15c when first heating, then by about 10c when cycling around the target temp. I'm currently using bang bang, can PID be used with an SSR & AC or is it not recommended?
Thanks
Alex
Re: Advice On Powering Large (450 x 450mm) Heated Bed. September 22, 2015 05:04AM |
