So, I was going through the Folgertech config process and the first time through, I got to home the X axis and the Y axis. I moved the X axis and the Y axis, testing the controls. The Z axis was a bit of a problem, so I powered everything down, took the stop switch off, put it back on and powered everything up again.
Followed the process. Got to the home X axis part, and nothing?????? Tried Y axis..nothing?????
Board is on. Program loaded successfully. Fan is on. Stop switches leds light up when pressed...so what am I missing??? I'm new at this, but understand the process. The Manual Control page from RH, shows "Idle". I'm at a loss and would appreciate any help. Running version .95F of PH if that helps.
