I got bupkis...printer not responding to Repetier Host
Posted by Flyer
October 05, 2015 06:34PM
So, I was going through the Folgertech config process and the first time through, I got to home the X axis and the Y axis. I moved the X axis and the Y axis, testing the controls. The Z axis was a bit of a problem, so I powered everything down, took the stop switch off, put it back on and powered everything up again.
Followed the process. Got to the home X axis part, and nothing?????? Tried Y axis..nothing?????
Board is on. Program loaded successfully. Fan is on. Stop switches leds light up when pressed...so what am I missing??? I'm new at this, but understand the process. The Manual Control page from RH, shows "Idle". I'm at a loss and would appreciate any help. Running version .95F of PH if that helps.
Re: I got bupkis...printer not responding to Repetier Host
October 05, 2015 08:34PM
Did you home it (G28) first?
- Tim
October 06, 2015 12:28AM
II keep getting "Access to the port 'COM4' is denied in version 1.56. But everywhere I look, everything is set to COM4???
October 06, 2015 04:32AM
Did you try unplugging the usb connector and plug it in again? This usually happens when you power down the printer without disconnecting in repetier.
