I'm very new to 3d printing and was offered an 3Dprinter no one was using anymore.
From what i found in the wiki it must be a prusa i2.
I managed to hook it up to my laptop and when i connect with pronterface it says "Marlin 1.0.0", supose this is the firmware.
First thing I printed was a 20x20x20 cube. While it has perfect 20mm in x axis, the y axis is considerably short with only 17mm, height a little off with 19mm.
What are my options to correct this?
I read that one way is to reupload the firmware with adjusted values the motorsteps per unit for x,y,z,e.
But i'm not sure if there are other parameters i have to know about, which could get lost with a reupload. Is it possible to read the current values for x,y,z,e axis steps per unit from the firmware to correct them without reuploading the whole program?
Could it be a hardwareproblem (the printtable moves a little "stiff" in y-axis, otherwise everything seems ok to me)?
thanks a lot, every help appreciated
