static torque when powered October 20, 2015 10:36PM |
Re: static torque when powered October 21, 2015 02:15AM |
Re: static torque when powered October 21, 2015 02:09PM |
Re: static torque when powered October 21, 2015 02:46PM |
o_lampe
That's physics...
As soon as the weight drops a bit from a skipped step, it gains velocity which adds to the static weight. This causes a chain reaction.
-Olaf
Re: static torque when powered October 21, 2015 09:15PM |
Re: static torque when powered October 21, 2015 09:28PM |
julianh72
You need to look at the firmware that you are running, and what it does after it completes the "Move" commands that you send to it.
For example, all of my steppers are "locked solid" when the printer is under the control of the Pronterface UI (so current is being supplied to all motors, held in position and ready to move), but at completion of a print job, the G-Code includes a M84 "Stop Idle Hold" command [reprap.org] , which means I can manually move the X and Y axes, wind the Z-axis rods independently (if I need to re-level my X-Axis for example), and turn the Extruder (if the extruder is still hot, or there is no filament loaded).
I would guess that your control software that you are using for testing is de-energising the steppers when it has completed the Move commands, so they have no static holding torque.
Re: static torque when powered October 22, 2015 03:58AM |
Re: static torque when powered October 22, 2015 07:55PM |
o_lampe
#define DISABLE_E false // For all extruders
In Marlin this line looks like that. I don't know, if you can change this with an M-command using pronterface, maybe you'd have to reflash the firmware.
-Olaf
Re: static torque when powered October 22, 2015 09:11PM |
