Extruder Motor Issue
November 04, 2015 10:18AM
I recently had an issue with my M505 prusa I3 where I had to connect it to another pc. Once I moved the printer and starting printing again I noticed that during the print the extruder motor is not moving to pull the filament. I test the extruder in repetier manual control and the motor works to pull the filament fine. I am not sure if any settings have changed or if the board is the issue.
Thanks,
Keith
Re: Extruder Motor Issue
November 06, 2015 02:30PM
Make sure your thermistor is still reading correctly and check that your control software didn't switch from relative coordinates to absolute or vice versa.
