Push-fit connectors keep failing November 12, 2015 03:21PM |
Re: Push-fit connectors keep failing November 12, 2015 08:46PM |
Re: Push-fit connectors keep failing November 12, 2015 10:44PM |
Re: Push-fit connectors keep failing November 12, 2015 11:03PM |
Re: Push-fit connectors keep failing November 13, 2015 02:45AM |
jbernardis
I have recently commissioned a printer with a dual bowden extruder arrangement. I am using these fittings that I have purchased from McMaster.
Twice now, I have left a print unattended only to come back to find that the tube has slipped out of the fitting at the extruder, and there is a pile of filament on the floor. Afterwards, the fitting no longer holds on to the tubing. I can insert it, but the fitting does not grip it.
Does anybody have any advice for what to do here, or perhaps might there be some alternative fittings I can use here.
Thanks
Re: Push-fit connectors keep failing November 13, 2015 01:12PM |
