Buildtalk question?
Posted by bianchi
Buildtalk question?
November 14, 2015 06:17PM
Guys,
Does Buildtalk have a much better sticking quality than painting mask ?
I had printed with painting mask, the result was not bad at all...
If I want to change to buildtak, it means I need to recalibrate the Z limit again.....don't I ?
Thanks
Re: Buildtalk question?
November 14, 2015 09:42PM
I would say it's definitely more adhesion than with tape. It's only marginally better than tape, though. If you really wanna upgrade, look at a nice thick PEI sheet. If you get the 1/8" thickness, you don't need to glue it down to anything, just clamp it to your glass/flat bed.
November 14, 2015 11:14PM
I have prepared 1.6mm galvanized plate, it's stiff and I'm gonna stick Builtalk on it and give a test....
November 15, 2015 02:30AM
The limitations of buildtak are that the surface is very delicate and the sheet will peel up during the first large ABS print that would otherwise normally curl up.
November 15, 2015 04:00AM
What's the different between PLA and ABS ? which one is better ? thanks
